I just got this recorder for my bday, i was wonder what the difference between the XP/SP/LP/EP is for a regular DVD player,
I have 2 DVD PLayers, 1 is a sony DVP-NS700P and the other AWIA XD-DV370, this disc i recorder will not play on either of them,
Any suggestions?
One important thing to note is that the E30 records on either DVD-RAM or DVD-R. If you use the DVD-RAM, it will not play on most DVD players.
XP: 1 hour per disc (bit rate ~ 9500 Kbits/sec)
SP: 2 hour per disc (bit rate ~ half of the above)
LP: 4 hour per disc (half again)
EP: 6 hour per disc (~ 1500 Kbits/sec)
LP and EP really sucks in quality (for me)ktnwin - PATIENCE -
So far, i've only tried those two players, i really do not want to buy a new dvd play i would figure since the sony is less than a year old, it should support it.Originally Posted by musher70
Think it could be the disc's like i said they are made by maxell.
Thanks -
Did you finalize the DVD-R?
Did you check the DVD Players compatibility list to see if your DVD players can play DVD-R? -
Thanks guys, that was my problems, apparently i did not finalize the CD correctly.
Thanks everyone!
Panasonic DMR es10 working question
By mammo1789 in forum DVD & Blu-ray RecordersReplies: 7Last Post: 24th Mar 2012, 19:02 -
Question about USB recording on the Panasonic DMR-EZ48V
By afroconnection in forum DVD & Blu-ray RecordersReplies: 1Last Post: 5th Sep 2010, 10:06 -
DMR-ES10 Passthrough Question
By zeroprobe in forum RestorationReplies: 3Last Post: 28th Aug 2010, 19:26 -
panasonic dmr E30 compatibility
By jimakros in forum DVD & Blu-ray RecordersReplies: 5Last Post: 22nd Dec 2008, 13:19 -
Question about Dubbing on the DMR-ES40V
By kbRenePerez in forum DVD & Blu-ray RecordersReplies: 16Last Post: 18th Nov 2007, 15:28
