I just downloaded a certain movie in two parts (717 and 697 mb) that when i try to open to convert in TMPG gives me the message "file type unsupported." The thing is all of my other .avi's work?? Can anyone suggest a reason for this??
Get gspot. It tells you what codecs were used in most files.
"Knowledge makes a man unfit to be a slave."
Frederick Douglass -
Try installing DivXPro5.03 [Newest Version] also IF that doesn't help just install Nimo Codecs Package 5.0,
Hope it works for you, replay back IF you have problems.
This guide tells you the codecs you NEED without all the spyware that the Nimo Codec Package contains:
http://www.vcdhelp.com/forum/userguides/135217.php
Hope That Helps!!!
:P
Y/C Separation 2D/3D could this be the only reason?
By DB83 in forum Capturing and VCRReplies: 2Last Post: 9th Jul 2010, 14:13 -
any reason this wont stream on xbox360
By carlos28355 in forum Newbie / General discussionsReplies: 3Last Post: 21st Jun 2009, 22:17 -
MeGUI queue pausing for no reason
By The111 in forum Newbie / General discussionsReplies: 0Last Post: 19th Mar 2009, 20:29 -
Computer Shuts Down For No Reason
By bryankendall in forum Newbie / General discussionsReplies: 7Last Post: 23rd Nov 2008, 17:33 -
What is the main reason you backup dvds?
By yoda313 in forum PollsReplies: 15Last Post: 25th Jun 2007, 13:52
