Hi I've saved a movie I created using Windows Movie Maker v2. It saves it in WMV format, but I then want to create a VCD from it. I like to use Nero to create, but believe I need to convert it first to MPEG??
Can someone help in what software/convert util I need please
Glen![]()
Try to load it into TMPGEnc. If you can, just encode it into VCD format, then let NERO burn.
Hello. -
I had one that I downloaded off the internet, TMPGnc would not touch it but I loaded it into Nerovission Express and it encoded and burned me a perfect VCD. I'm not sure what the file was but that's what I think it was.
harrymj3 -
http://www.stoik.com
Go to the download page and get the stoik video converter.
It converts .wmv to .avi or vice versa."Knowledge makes a man unfit to be a slave."
Frederick Douglass -
"VideoStudio 7 works with a wide breadth of file formats, now including Windows Media Video as well as industry-leading support for Sony MICROMV™"
However, UVS 7 doesn't get released until later this month (February). UVS always used to encode WMV, but would not decode WMV; this will be a welcome feature. They haven't started taking orders for UVS7 yet.
http://www.ulead.com/aboutulead/press/pr01-23-03.htm
Now if it would just open realmedia video...As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
Originally Posted by vh5150"Knowledge makes a man unfit to be a slave."
Frederick Douglass
Convert audio file og WMV HD video
By karebo in forum AudioReplies: 2Last Post: 27th Aug 2011, 09:15 -
Cannot convert 7.5 GB mkv file to wmv?
By killazys in forum Video ConversionReplies: 1Last Post: 17th Feb 2010, 19:07 -
How to convert .CBR video file to WMV or AVI?
By microline2009 in forum Newbie / General discussionsReplies: 2Last Post: 22nd Jan 2009, 02:05 -
wmv file wont play nor convert
By excitezone in forum Newbie / General discussionsReplies: 7Last Post: 18th Dec 2007, 12:56 -
May I know which software can convert a wmv or asf file to better viewable
By sniper in forum Newbie / General discussionsReplies: 4Last Post: 6th Aug 2007, 12:22
