I'm trying to make some motion menus in DVDSP, and this requires an MPEG2 video file with four small videos composited onto a solid color background, for the buttons. Can anyone tell me what software is capable of compositing four small video clips onto a static background, and exporting to either MPEG2, or any QuickTime compatible video format? Some tips on how to accomplish this feat would be greatly appreciated.
I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté."
I was able to accomplish something similar to this using Final Cut Express. I made my movie in FCE, exported as .mov and used FFmpeg to convert to mpeg2 (keep elemental streams checked). Add m2v (mine had no sound track to it) to DVDSP and make your buttons.
Hope this helped.
jbcandkcI'm just sitting here watching the wheels go round and round.
-John Lennon -
I managed to do this with Quicktime Pro only. It will let you import the still and add imported video elements (.mov in my case). It will also allow you to resize the video elements and move them around. You are best off adding any text to the still using Photoshop. The final can then be exported to mpeg2 and imported into DVDSP. Hey I did it, had fun and went back to iDVD.
after effects can do this great, after effects(ae) is pretty much photoshop for video if you're not familiar with it. very powerful tool. fcp, premeire you'll also be able to do in these too.
pants on, pants off, pants the floor. -
Excellent, i'll get working on the QT Pro solution, never knew I could composite with QT. Thanks guys!
I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté." -
In QT Pro, how do you get the background pic to display during the entire length of the video I added to it?
*edit*: Nevermind, just figured it out . . . I'm golden. Thanks for the help!I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté."
Video compositing??
By AcousticRocker20 in forum LinuxReplies: 0Last Post: 30th Jan 2011, 15:12 -
Avchd ?'s - motion menus, shrinkers and more
By yoda313 in forum Authoring (Blu-ray)Replies: 12Last Post: 11th Jun 2010, 18:40 -
Free Software for Motion Menus?
By thomasj in forum Newbie / General discussionsReplies: 5Last Post: 21st Nov 2008, 15:03 -
Motion Menus in DLP
By ckurowsk in forum Authoring (DVD)Replies: 8Last Post: 8th Sep 2008, 09:23 -
Problem with DVDlab and 16:9 motion menus
By sektionschef in forum Authoring (DVD)Replies: 3Last Post: 8th Aug 2007, 06:11
