When do you use one vs. the other? Any benefits/advantages either way?
I noticed under IFO ripping, you can stream process.. what's the difference b/t stream processing vs. using IFOedit and stripping the streams you want??
I've read up on DVD Decrypter but am not understanding.. I'm backing up Bourne Identity right now--which method should I use to rip? Thanks!
Rip in "Files" mode and the strip if you want to using IFOEdit.
http://encoding.n3.net <-- for all your DVD and CD backup needs! -
File mode for single layer disks that can be burned to DVD without any processing. IFO mode for dual-layer disks if your going to transcode to DVD or SVCD.
Using DVD Decrypter should I use .ISO or .IFO file !
By augustya in forum DVD RippingReplies: 21Last Post: 29th Mar 2012, 11:44 -
Confused! Confused! Confused! VCR to DVD; major question Toshiba Diomage SV
By CAnn12 in forum Capturing and VCRReplies: 0Last Post: 5th Feb 2011, 11:26 -
Can't rip DVD, invalid IFO
By indijay in forum DVD RippingReplies: 3Last Post: 24th Jan 2009, 00:57 -
rip with DVDFab HD Decrypter record with what?
By Onceler2 in forum DVD RippingReplies: 3Last Post: 30th Sep 2008, 10:22 -
DVD Decrypter IFO I
By drstew in forum DVD RippingReplies: 6Last Post: 2nd Dec 2007, 23:42
