I know this has been discussed alot here but none of it directly relates to my problem.
Recently I've had lip sync problems with around half of my downloaded divx/xvids. This has never happened before and I'm not doing anything diffrently. I have created lots of VCDs and never had this problem. Here is how I usually convert an avi to VCD:
search for bad frames and remove if any using VDub mp3
Save the sound uncompresed using regular vdub
Convert to mpeg using TMPGEnc
Aurthor with VCDEasy
Can anyone help?
stop using mili vanili software. Sorry couldnt resist....
More than likely the divx file is less than the standard frame rate and the person who made the divx did a cheapo job on making the divx. There is a guide in the guide section (one of the newer ones) that will fix the issue. Basically, you have to see where the lip sync goes out, copy the time down. extract the audio, fix it, remux it, then reburn it. -
Milli Vanilli........
So your'e the one who remembers them!
Strange lip sync problem
By joe_kargan in forum Video Streaming DownloadingReplies: 1Last Post: 29th Apr 2011, 16:36 -
Media Player Classic Lip Sync
By rckowal in forum Software PlayingReplies: 2Last Post: 9th Jan 2011, 12:31 -
dvdauthorgui bad lip sync problem
By prioryjim in forum Authoring (VCD/SVCD)Replies: 5Last Post: 2nd Dec 2009, 04:47 -
How to fix gradual loss of sync once and for all
By Acidagent in forum User guidesReplies: 76Last Post: 22nd Oct 2009, 06:39 -
IC For Lip Sync Correction
By SingSing in forum AudioReplies: 3Last Post: 4th Jun 2007, 15:53
