Hey guys,
I recently got an HDTV. Currently I author my disks so that the source is stored progressively (Progressive 23fps Pulldown, or 29fps progressive). I was tempted to spend money on a $400 CN player, but I was thinking. Those players really make the picture quality better by deinterlacing right? But if my movies are already progressive, doesn't that mean, even a really cheap and crappy progressive DVD player will still work just as well, since all that player needs to do is shoot out the original picture without interlacing it?
I would assume ONLY if the disk was authored interlaced internaly, then would a crappy DVD player show problems since deinterlacing would be its weak point.
Is this the case?
Read through this
http://www.hometheaterhifi.com/volume_7_3/dvd-benchmark-introduction-9-2000.html
Generally the thing about higher end progressive scan players isn't necessarilly that it gives you a better overall picture, its that it doesn't have the annoying errors that a cheaper progressive scan player has. This site goes through problems you might see on a cheaper progressive scan player. -
Ah, I was sure someone would mention this
But the key about this case is that all the video is edited and processed before authoring the DVD. This means you can do de-interlacing before hand removing the task of the DVD player to do it. This means there is less changes of a glitch to occure. In addition, since you mastered the video yourself, things like flags and such should be pretty consistant. After all, if your movie is true progressive, and you set it as such in Tmgpenc, it should give you a simple uniform video output with no odd variations and glitchs which might throw a DVD Player off.
Protron DVD player PD-007 in Progressive mode How do I reset.
By joe347 in forum DVD & Blu-ray PlayersReplies: 6Last Post: 25th Nov 2013, 20:36 -
How to progressive Upload video & progressive download
By video909 in forum Video Streaming DownloadingReplies: 1Last Post: 6th Mar 2010, 05:17 -
Progressive MP4 in embedded flash video player
By The111 in forum Newbie / General discussionsReplies: 2Last Post: 14th Mar 2009, 19:58 -
Progressive vs. RGB output on upscaling DVD player & HD TV
By iansport in forum DVB / IPTVReplies: 5Last Post: 11th Jul 2008, 06:35 -
Can progressive video be saved as DV without losing progressive advantages?
By boblin2 in forum Video ConversionReplies: 7Last Post: 22nd Jul 2007, 14:35
