Hi I have a problem with nero when im trying burning imagefiles. I have tried to reinstall nero and used different imagefiles but i always get the same error where it says theres an invalid field in parameter. Any idea what it can be?
Homer: "Facts are meaningless. You could use facts to prove anything that's even remotely true."
The cue/bin could be corrupted?
Try to re-create the cue/bin images, otherwise use the latest of VCDwizard to rip the (cue/)bin file and recreate/rebuild a new cue/bin (or directly to a Nero NRG-image).
VCDwizard also can tell you if it would that the cue/bin isn't a valid (S)VCD image.
You can get VCDwizard at labDV.com.
How to Extract an ISO Image without burning to dvd?
By skorpinok in forum ComputerReplies: 8Last Post: 26th Sep 2018, 03:07 -
Update ISO(Image File) file
By Anurag in forum Newbie / General discussionsReplies: 3Last Post: 13th Sep 2009, 03:29 -
Best Image Quality burning AVI to DVD..
By UncleRuss in forum MacReplies: 9Last Post: 29th Jul 2009, 05:06 -
Help me! I can't play file *.mds file after i 'mount image' using daemon
By i_nui in forum Newbie / General discussionsReplies: 2Last Post: 19th Jun 2008, 14:04 -
problems burning movie file
By lynette00 in forum Newbie / General discussionsReplies: 4Last Post: 11th Jan 2008, 06:40
