I'm ripping a DVD for transfer to a VCD medium. When I preview it in DVD2AVI, it displays the Film Type as FILM, the aspect ratio as 16:9, which is all very clear. The problem I'm having is that it's displaying "progressive" AND "interlaced" in the Frame Type window. It flashes both words on the Statistics display window, almost as if some frames are progressive and some are interlaced. I can't tell what to put down in TMPGEnc for the video source type as a result.
Also, if I'm putting a film on VCD, do I want to perform inverse telecine or 3:2 pulldown on it and burn it as a 29.97 fps NTSC VCD?
Jeremy Morrow
Hamilton, Ontario, Canada -
I may be wrong but if the source is FILM and you check force film in DVD2AVI then it doesnt matter, you dont need to worrry about interlacing. One way to tell is to open the d2v in TMPG and goto settings/advanced/double click the deinverlace option. Scroll through a few sceens. If you see horizontal lines on the picture then you should use the deinterlace option. I always use double.
Hope this helps
NTSC : progressive or interlaced
By mathmax in forum Authoring (DVD)Replies: 54Last Post: 2nd Feb 2012, 07:06 -
Progressive Vs Interlaced?
By shagratt71 in forum Video ConversionReplies: 4Last Post: 26th Dec 2011, 09:22 -
Progressive and Interlaced Chroma -- again!
By Anonymous344 in forum Newbie / General discussionsReplies: 6Last Post: 23rd Apr 2011, 07:14 -
de-interlaced means progressive ?
By codemaster in forum EditingReplies: 19Last Post: 23rd Dec 2010, 06:08 -
Interlaced or progressive
By rank in forum Newbie / General discussionsReplies: 4Last Post: 3rd Jul 2010, 16:41
