As the topic says. I did a speed test last night and found that 2.5 is faster.
CCE2.5: 1.26
CCE2.66: 0.97
Has anyone done any sort of quality test or anything?
Thanx,
My specs:
AMD 1700+
256 DDR 2100
60gig WD 7200
etc. etc. etc.
a lot depends on what you are encoding and also if you have SMB ... quality between the 2 versions is about the same as far as i can tell for most things ..
I find that in DVD2SVCD, CCE 2.66 pukes me out with the message: "cannot locate ecl file" --- I can go in and continue manually, but it's a pain in the ass to do it at 3 in the morning. No problem with CCE 2.50, though. Must be some setting that I'm not seeing in CCE or DVD2SVCD. I'm using the latest version of DVD2SVCD, which says it works fine with CCE 2.66 now...
Anyone have any ideas how to remedy the puke-out?
CCE vs ConvertXtoDVD
By ranosb in forum Video ConversionReplies: 23Last Post: 5th May 2009, 20:14 -
CCE OPV
By name123 in forum Newbie / General discussionsReplies: 2Last Post: 7th Jan 2008, 12:03 -
best software for cce sp
By zookeeper525 in forum DVD RippingReplies: 12Last Post: 25th Dec 2007, 14:41 -
CCE-SP2
By Belfour in forum DVD RippingReplies: 10Last Post: 29th Sep 2007, 19:47 -
CCE VS DivX
By SteveF22 in forum Authoring (DVD)Replies: 9Last Post: 25th Aug 2007, 20:13
