i followed the author to dvd-r guide and it didn't work. i even tried doing what i used to do, but that didn't work. i always get the pop up at the bottom of the post. what am i doing wrong?
[/img]
Results 1 to 10 of 10
Remember, it will help if you say what it is you were doing. Were you encoding to a particular template? Were you using TMPGEnc or some other software, what exactly were the parameters your program finds fault with?
Hello. -
I was trying to burn a VCD to DVD. i've done it before, and I followed the guide on here when I did it. And i haven't encoded this. Maybe it would help if I encoded it?
Yes, as you will be using different parameters.
Hello. -
but what about this. i encoded a divx to svcd or vcd (i dont remember) and i get the same error.
What program were you using to encode your video?
Hello. -
i reencoded the svcd to vcd and tried burning this morning and it still gave me that error. does anyone else know whats wrong?
because its possible and i have done it before and it takes 14+ hours to convert to dvd. and my moms dvd player plays vcd on dvd and i dont want to waste any dvd-r's so i just wanna do what im used to doing.
What did I do wrong???
By olofen in forum ffmpegX general discussionReplies: 1Last Post: 12th Jul 2008, 09:36 -
Where is my burn going wrong?
By ryan24 in forum DVD RippingReplies: 17Last Post: 21st Feb 2008, 12:25 -
Somethig Wrong!!!
By SIRCOOKS in forum ComputerReplies: 11Last Post: 7th Feb 2008, 15:03 -
Where did it go wrong?
By video_enthusiast07 in forum Authoring (DVD)Replies: 1Last Post: 31st Dec 2007, 18:17 -
OK, what's gone wrong here?
By EddyH in forum Authoring (DVD)Replies: 6Last Post: 30th Jun 2007, 04:11
