    Dec 2002
    hiya, im trying to code a film with a soundtrack in ac3, tmpgenc will not load/recocnise the audio file,
    is there any other way to rip the sound, i got goldwave, but always does an illegal operation when i rty to do a batch encode, when i loaded soud file in then clicke on "save as" it just shuts the prog down. So please advice me of any other software i can use..
    thanks in advance
  2. Have you tried virtualdub?
  3. If you have the WAV file then you can use BeSweet to create an AC3 file. If you're then creating a DVD you will need an authoring program that can import AC3 e.g. Maestro
    Dec 2002
    yes ive tried virtual dub and it says " the requested audio compression is not compatible with the input format, check that the sampling rate and channel count of the input match those of the requested format"
    i tried to save it as a wav file.
    besweet wants an ac3 file or some other sound format file, which i cant give it cos its in the video file , so im stuck with besweet,
    still drivin me crazy this, cant tmpgenc support files with an ac3 sound format, if not someone tell them to get on with it.
  5. Starting with the avi file you can use TMPGenc to extract the audio into a wav file. Writing from memory I think it's on the file menu, save audio, and then select WAV.
    Once you have extracted the wav file as above use BeSweet to convert the WAV into AC3 (I use it all the time and it is quick and easy).
    Once you have the AC3 file use Maestro as mentioned earlier (if you're making a DVDR)
  6. Use HeadAC3he/BeSweet to extract .ac3 audio from the .avi and convert it to 2 channel stereo .wav.
    From what I can tell Tmpgenc doesn't encode ac3 .mpg files.
    But there is a AC3 VirtualDub around somewhere that can encode .avi's and maybe extract them. But you still need to re-channel the .ac3 to .wav
    "Knowledge makes a man unfit to be a slave."
    Frederick Douglass
