I have just backed up a dvd by using smart ripper, CCE and Spruce Up.
I have imported the m2v and ac3 into to Spruce Up wihich took about an hour. I then chaptered the file created a menu system ready to be exported.
I then decided to export using the Title type, which creates all the Vob files etc. I left it on for 10 hours yesterday and it had only done 50%. ! Is this right it should take soooooo long ?
If it is right is there another program out there that can do the same process quicker because it has already taken 20 hours to enconde the film?
If anyone is interested here are my system specs.
Athalon 1.4 mhz
Windows 2000
512 MB ram pc100
Hard drive 40 gig 5400rpm.
Geforce 2 gfx card.
pioneer 105 dvd writer
40x aopen cd writer.
Thanks,
Le monkey
Results 1 to 1 of 1
.ifo/.sup subtitle pair - what's in the .ifo?
By MilesAhead in forum SubtitleReplies: 2Last Post: 5th Mar 2010, 00:02 -
Medieval helpdesk. What tech support was like in the middle ages.
By freebird73717 in forum Off topicReplies: 2Last Post: 5th Jul 2009, 00:05 -
Can I edit video_ts.ifo to link missing vobs to DVD?
By Srivas in forum Authoring (DVD)Replies: 1Last Post: 21st Jun 2008, 11:39 -
4 separate IFO files > one IFO to govern the full .VOB video
By Salva Veritate in forum EditingReplies: 4Last Post: 20th Aug 2007, 14:38 -
SVCD2DVD taking AGES to convert files.
By smileymyley in forum SVCD2DVD & VOB2MPGReplies: 7Last Post: 22nd Jun 2007, 15:53
