i have try to mux wav (PCM) with m2v and tmpgenc reject it...
TMPGEnc will not accept PCM wav files for muxing, you need to convert the audio stream to mp2.
In TMPGEnc select audio only as the stream type, then select your wave file as the audio source and then encode. You can now use the resulting mp2 file to mux with your video. -
IFOEdit will accept a wav file if you have to have LPCM audio for the quality.
Transform .m2v +. wav to full MPEG-2 dvd spec file?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 2Last Post: 14th Oct 2011, 08:13 -
Convert/Mux .m2v and .wav into mpeg for DVD??
By Beavis in forum Video ConversionReplies: 2Last Post: 22nd Jul 2011, 14:46 -
How to mux a m2v file with 44.1khz, 16-bit wav?
By seven_deuce offsuit in forum Newbie / General discussionsReplies: 2Last Post: 24th Apr 2011, 22:25 -
Freeware to mux mpeg-2 (m2v mp2) (NOT TMPGEnc)
By 2397to2997 in forum Video ConversionReplies: 12Last Post: 18th Aug 2010, 15:42 -
toast won't do wav, so using mpg file instead of m2v file gets round that?
By jboyd in forum ffmpegX general discussionReplies: 12Last Post: 16th Nov 2007, 14:08
