Ive followed the dvd2one guide on the website. For some odd reason I cant see the movie portion which should be about 30 chapters in the dvd i want to condense. All I see is 6 chapters which are extras. I downloaded the trial version and bought the real version. It happened in both copies. Am i doing something wrong. I ripped the dvd to my harddrive with all the .vobs and ifo, bup files. Do i include all the files or use another program in order to make dvd2one work? Im all out of ideas. Ive tried this since a few days after the program was released.
I use dvddecrypter in the file mode and allow it to choose the files to copy to hard drive.
I then use this folder as the input and create another folder as the output.
I then burn with nero.
are you using dvddecrypter or smartripper?
regards
Jim -
Can I ask, when burning with nero do you use dvd udf or dvd udf/iso ?
Thanks.
dlb. -
Hmm try this. Re-rip the movie in File Mode using dvd decryptor. Next open dvd2one and select the dir where you had decyptor rip your files to, then select a blank dir for your processed files (the ones you will burn). Choose your audio stream you'd like to keep in dvd2one and whether you want subtitles, then click Next and wait till it finishes. Then if you're gonna use NERO, open Nero and choose DVD_VIDEO from the list on the left-side of the window. For your Label, type it in whatever you want. I name it whatever the name of the movie is.... Next, drag your VIDEO_TS files into the red folder in NERO. Not the VIDEO_TS folder itself, but the contents inside of it. Burn with UDF ISO 1.02 and you should not have any problems unless you have a software program that is interfering with your drive and /or software. EZ CD products will cause problems for sure . not sure on other brands. Take care and do not give up, you'll get it 8)
In Nero DVD Video where do you choose the udf iso option, I could not see anything there to change.
dlb. -
You will not be able to change the UDF file option version unless you choose to have NERO create a UDF/ISO DVD. That option is near the bottom of the left-hand window. If you choose DVD_VIDEO, UDF 1.02 is set by default.
How to PROPERLY burn DVD2ONE DVD's using TOAST 6.0
By galactica in forum MacReplies: 170Last Post: 30th Mar 2012, 03:48 -
Just can't get stabilization work properly.
By Jim Halpert in forum Newbie / General discussionsReplies: 9Last Post: 24th Nov 2009, 12:58 -
Can't get DGIndex to work properly
By iTayb in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 38Last Post: 22nd Aug 2009, 22:38 -
Can't get the .TS audio to work properly
By mkvbob in forum Video ConversionReplies: 3Last Post: 25th Jul 2008, 17:04 -
Can't get .mkv subtitles to display/work properly
By ChronoSquare in forum SubtitleReplies: 3Last Post: 26th Dec 2007, 16:36
