I have a digicam that allows recording in either format. Which yeilds the best quality?
thx.
Tygrus
MJPEG has different quality levels. So it could be better, same or worse than DV. Depends on the setting that is used in the camera.
What sort of camera is it?
You might just have to take some footage and see for yourself. -
AVI is everything, M-Jpeg is just a codec used to store the video in the AVI, so you always will get an avi.
If you're using a cam-corder, then only use m-jpeg if you're sure if it is an analogue camcorder and it cannot create DV (DV also is a codec, but always delivers better quality than m-jpeg!), otherwise use the DV-codec.
The main differance between DV and m-Jpeg is that mjpeg does more video-compression (that's also why you get worse quality if you've got the possibility to use DV).
DV usually is a vast data-rate (at 3.5MB/sec), while mjpeg mostly uses a much lower bitrate (so some diskspace is also required with DV).
AVI Motion JPEG to x264 in Matroska MKV container
By Michielvsb in forum Video ConversionReplies: 2Last Post: 20th Apr 2011, 04:12 -
Best Conversion from AVI (Motion JPEG) to MP4
By cademichaels in forum Video ConversionReplies: 3Last Post: 12th Apr 2010, 22:34 -
How to convert to AVI Motion JPEG?
By BobAchgill in forum Newbie / General discussionsReplies: 1Last Post: 10th Dec 2008, 17:59 -
JPEG to AVI (or MPEG2) via timing cue-sheet?
By NetRodent in forum Video ConversionReplies: 0Last Post: 31st Aug 2008, 10:49 -
Which of these TV-cards capture analog to AVI, using Huffyuv or M-JPEG,...
By dOdGE dIZ in forum Capturing and VCRReplies: 15Last Post: 9th Mar 2008, 09:01
