Here's the thing. I downloaded some divx movies for my son and planned on converting them to vcd on 1 disk. I extracted the .wav file, and used TMPG to encode and fit on one disk. All went well until I tried to play it in my DVD player. Obviously the audio and video don't match up.
What can I do to match these up, and still make it able to fit on one disk? All help is appreciated.
Results 1 to 15 of 15
What did you use to extract the audio??
"I´m not popular enough to be different" -
Try going in the guides section for Mpeg Syncing Audio Fixing, they are very helpful, and work. Try em out and see if they work, if it doesn please reply back for more help.
Hope it helps. -
Edit Section*
Scroll Down & Keep Reading The GREEN bars going across the screen
>"How to repair downloaded video clips or fix audio sync problems"< -
Ok. tried it. it wants me to use VirtualDub. For some reason my VirtualDub won't work for me. I had to use another program to extract the .wav file. Any other ideas? I really appreciate the help.
Any other ideas?
aren't you following the guide ?
which guide are you following?
you said everything was fine until you played it on the dvd player so maybe the dvd player has a problem?
I went to the section you recommended. It was the last one of the section, titled, "How to fix audio sync problems in a AVI, DIVX, ASF FIle. It was very confusing to me. It routed me off to another site. It took me to some DOOM9.net. This site is very confusing. Nonetheless, it wanted me to use VirtualDub. For some reason, I can't get VirtualDub to work on my system. I don't know if it has anything to do with XP, but if you have any other words of advice, please do.
not sure if this will help,but you can give it a shot:
https://www.videohelp.com/forum/viewtopic.php?t=119210 -
This information is all and good. And trust me, i appreciate everyone's input. but I need to get the movies on one disk. I don't care if I lose quality. Everywhere I turn, I need to useVirtualDub. I can't even get VirtualDub to pull up a movie. Recap:
I need a movie on 1 Disk,
And need the audio to work. Please someone help!!! -
Originally Posted by alanra
well it seems that you need to do alot more reading/research. you don't have a problem with your file,you have a problem with virtual dub.
trust me when i say that virtual dub is going to be one of your best friends.you just need to figure out how to use it on your system(IE. any conflicting programs,missing vdub files,etc.) -
Alright, try using VirtualDubMod it's a lot better then VirtualDub, almost the same interface, has new features. I forgot where I got it from, try searching for it.
VirtualDubMod, I heard their is a new plugin that you can install and you can also open VOB/Mpeg2 files aswell.
Try that out and see if that works.
Another really handy program you can use is Goldwave, for audio editing. It's really good. Try that out aswell.
Both these programs are user friendly and pretty easy to understand.
Try reading and researching a little bit also.
Reply back.
Virtualdub keyframe picture doesn't match the actual video
By yuvid in forum EditingReplies: 1Last Post: 1st Feb 2012, 01:57 -
Audio does not match with the video
By c018279 in forum Blu-ray RippingReplies: 1Last Post: 31st Mar 2009, 04:10 -
Video and Audio does not match
By hzgg2 in forum Authoring (DVD)Replies: 1Last Post: 1st Aug 2008, 19:50 -
cant get audio to match video
By loa909 in forum Newbie / General discussionsReplies: 4Last Post: 31st Mar 2008, 06:35 -
Video Type Doesn't Match prob when compiling DVD Lab Pro project
By ulrichburke in forum Authoring (DVD)Replies: 6Last Post: 11th Dec 2007, 13:31
