Could someone please help
I have downloaded a some movie files on mirc and each of them have given me the boot like file has been rejected is there a reason why it has happened to me every time I download
Ive have tried for days and still no conclusion
Please Please Please help
Results 1 to 9 of 9
What connection speed are you on (i.e dial-up, cable etc)? The reason I ask is that you may be downloading from an FServ or XDCC where you are not meeting the minimum download speed required so the Bot/FServ boots you.
Also it may be having problems downloading if you are behind a firewall or proxy. -
I'm running on a 56k is that not good for d/l on mirc if not whats the best internet connection for mirc, cable etc
There is essentially nothing wrong with a 56k modem for downloading if you are prepared to wait.
The problem arises when you go to download say a movie from a XDCC/FServ. Now the operater of it might have in place a minimum download speed you need to achieve otherwise it cancels your download. Basically they do this so as many people have access to the files as possible and are not held up by someone on like a 28k modem download a 800mb file at .96k/sec when someone on like a T3 connection is waiting and can download it at like 960k/sec.
The download minimum's werent all that common a few years ago but as more people move to broadband and files are getting bigger then their use has increased.
If you seriously want to download big files I would recommend at upgrading to cable/dsl as you are 99% likely to meet the download limit. As well it will cut the time (for an 800mb file) to download from like 30 hours to 3 or less. -
I am using WinXP with Norton Personal Firewall 2003.
I installed mIRC but how do I set up the firewall so that I can go on mIRC ?
Help please. -
mIRC is the the program , IRC is what you mean .
open ports 6667 to 6669 and Ident port 113 -
BJ_M, when did you become a moderator ?
The Ident port is 113 on my mIRC setting but how do I set "open port 6667 to 6669 " ? -
Thanks heaps Pacmania I think I will upgrade my modem to cable, Its seems like everyone else has a faster connection so I think I'll be like everyone else.
thanks again
Brandyn
MIRc shuts down
By DuBsTaR in forum ComputerReplies: 2Last Post: 22nd Oct 2007, 14:23 -
mIRC Links in Firefox
By Xenogear900 in forum ComputerReplies: 1Last Post: 15th May 2007, 11:52
