Is it possible, i have loads of VCD's made from MPEG/MPG But whenever i try to burn an AVI or ASF file, it says it must be converted to MPG prior to burning, is there any way to get around this in NERO, or another program that will burn AVI & ASF to VCD, i'm not really worried to much about quailty loss in this case, the video file isn't in the best quailty anyway.
VCD's are MPEG1-movies (SVCD and DVD are MPEG2). So if you want to make a VCD you will have to convert the file to MPEG1 with an encoder or let NERO do it for you (I suggest you don't let NERO do it and use TMPG or Panasonic - or whatever encoder you like) So the answer is NO!
Jack -
The answer is yes if you want to burn the files to cd in data mode (iso9000), in which case they can only be read by a pc. Any burning program can do that.
"Art is making something out of nothing and selling it." - Frank Zappa -
hes asking if he can burn avi/asf to vcd without converting to mpg. the answer is no. vcd is mpg.
Right you are.
Converting ASF and AVI to AVI
By Tatl in forum Newbie / General discussionsReplies: 2Last Post: 16th Aug 2010, 17:18 -
converting asf to avi
By projecttemp in forum Video ConversionReplies: 2Last Post: 3rd Aug 2008, 09:40 -
converting asf to avi problem
By konig in forum Video ConversionReplies: 1Last Post: 6th Mar 2008, 16:37 -
Problem converting ASF to AVI/MP4
By yohu123 in forum Video ConversionReplies: 11Last Post: 16th Sep 2007, 13:24 -
TMPGEnc Error converting asf to MPG-2
By Caned_and_Able in forum Video ConversionReplies: 7Last Post: 6th Jun 2007, 11:07
