I am using Adaptec's Videoh! PCI to capture from SVHS to DVD and am noticing occasional skips in the picture that look like dropped frames. The Audio is fine, and Video/Audio sync is fine. I have tried several different bitrates using the Movie Mill capture software (version 2.71), and have also tried direct Off-Air recording to eliminate TBC concerns. I even tried recording SVHS to my miniDV camcorder and then playing back the miniDV into the Videoh! Analog input. No matter what I do, I always see occasional skips. And they always seem to occur at the same point in the Video, so it does not appear to be some random interaction with my computer (PIII 866 Mhz, 128MB Ram). I am authoring with Movie Factory 2.0 Demo without any MPEG2 modification except for setting chapter points. Any suggestions?
Results 1 to 1 of 1
Virtualdub VCR capture no dropped frames but 5400 inserted frames in 1 hour
By suloku in forum Capturing and VCRReplies: 12Last Post: 17th Aug 2011, 22:33 -
Dropped Frames
By SudsMalone in forum Capturing and VCRReplies: 4Last Post: 21st Feb 2011, 05:31 -
You Get dropped frames? That's for you
By themaster1 in forum Capturing and VCRReplies: 2Last Post: 6th Dec 2009, 22:21 -
Dropped Frames
By dano404 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 8th Mar 2008, 13:57 -
inserted frames without dropped frames in VirtualDub capturing VHS
By whschlebaum in forum Capturing and VCRReplies: 0Last Post: 23rd Aug 2007, 20:59
