just done a six episode disc using dvd2one and make it easy.
kept everything and it turned out perfect.
thingimijig.
Results 1 to 10 of 10
HERE
http://forum.doom9.org/showthread.php?s=&threadid=45104
Strength and Honor
Good Luck
dvd9to5 me
http://www.dvd9to5.com(;-{> Dd
Strength and Honor
www.dvd9to5.com
www.dvd9to5.com/forum/
"For every moment of truth there's confusion in life"
Black Sabbath/Ronnie James Dio -
I looked at MakeItEasy and I see no provision for handleing multiple PGC's ,so how can you say it handles TV episode DVD's??
@wulf.
when you take the main vobs with the multi pgcs and create ifo in ifoedit it makes it into one pgc.
so dvd2one treats it as one complete trancode then when you put it back into the original and ifoupdate, it seperates it again.
works great.
thingimijig. -
Do you have a guide for the IFOEDIT and MakeItEasy parts of the process? Any help you can give me would be appreciated as I have never used either of these programmes. Also do you rip just the main vobs or the whole disc?
Just rip the main movie, no need to get all the files. Just grab the ones you need and you're off to the races. Cheers
Make-It-Easy does work. I converted a Sopranos episode disk. It would appear to be a typical Tv episode disk. It has 4 episodes contained in 7 vob's controlled by one ifo.
I did learn that the amount ot padding you need should be double the amount of the extras. The Sopranos disk had 490Mb's of extras,so I used 1000MB's of padding and my final directory was 4.31GB's. DVD2ONE transcodes the padding along with the actual vob's.
I looked at the streams on the disk and discovered it had four audio streams so I had DVD2ONE transcode again but this time selecting only the primary audio stream,deleted the other three.
that put much needed Mb's back into the video stream.
Video quality improved noticably this way. -
Would this work (ripping movie VOBs containing multiple PGCs then creating IFOs in IFOedit) for encoding in CCE?
Thanks -
MakeItEasy sort of works
The program does what it is supposed to...however the menu selection doesn't all work...the first few buttons work...but towards the end of the film the last chapters won't work...I think it has something to do with the padding and removal
if anyone knows of how to fix this please let me know
Easy Question..Make duplicate of movie DVD
By WareISChris36 in forum DVD RippingReplies: 4Last Post: 23rd Jul 2011, 14:43 -
Easy Add Subs to episodes
By KnightHeart in forum SubtitleReplies: 2Last Post: 22nd Jul 2009, 14:34 -
F4V to AVI (or another format which is more easy to work with)
By swiftor in forum Video ConversionReplies: 3Last Post: 20th Feb 2009, 01:15 -
Any easy tool to make a DVD photos slideshow with the background?
By coody in forum Authoring (DVD)Replies: 9Last Post: 27th Sep 2008, 14:34 -
Easy Freeware to make DVDs out of mpg and avi files?
By gail22 in forum Authoring (DVD)Replies: 13Last Post: 15th Oct 2007, 18:31
