when I make svcd standard - I see it fine on the PC (media player) and through the burned cd in the home DVD player (pioneer 355)
Once I make the video in 2500 kbps and higher bitrate, I can see it good in the window media player, but I get some distorations in the burned cd/rw while playing it in th PC and in the home DVD player.
I am using NERO for burning.
Any idea of what is wrong?
some stand alone DVD players have 2x dvd drives so you can't have highter than the standard SVCD bitrate
Check the DVD players page to the left. Most standalones can't play x(S)VCDs w/ bitrates above 2800kbit/s. Sometimes thou a player can play MPEG1 files at a higher bitrate than MPEG2 files, so it's worth checking.
Yes, I understand rhe standalone SVS may not play xsvcd.
But why the CD in th PC can not play it?
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 05:23 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 04:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 22:57 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 12:39 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 04:03
