I tried to make a backup of my copy of Collateral Damage. First off, which IFO file do I select? I selected the one that had the movie time of 1 hour 48 mins. Second, what sound option do I choose? It has three different sound fields, one says English 6 ch. and one French, and one that is English 2ch. ... I selected the 2ch. one and now when I play the SVCD the sound is messed up and smoe sort of commentary plays instead of the voices. WHAT IS THAT?![]()
should I always select the 6CH? What is the 6ch? How come there are several IFO files? How come some are 6 mins and the others are the entire length of the movie? I am new to this
DVD2SVCD does a great job in selecting the correct audio and ifo's. Let it do its thing.
Thanks for your input. You are right, DVD2SVCD is automatic and I shouldn't mess around with it.
Audio Sound File Saved - Canot Hear Sound - Total Recorder
By Teac23 in forum ComputerReplies: 1Last Post: 15th Apr 2011, 15:29 -
Need advice getting rid of buzz sound at end of every word of video sound
By OM2 in forum AudioReplies: 18Last Post: 30th Oct 2010, 12:58 -
What are the downsides to having both onboard sound and Sound Card enabled?
By c627627 in forum Capturing and VCRReplies: 0Last Post: 21st May 2010, 15:44 -
AVI - sound with VLC , no sound Toast burned
By BattyRoy in forum MacReplies: 15Last Post: 27th Jul 2007, 21:21 -
DVD LAB : Different sound in different movie (MIXED SOUND): NOT WORKING?
By SteamrollerLive in forum Authoring (DVD)Replies: 2Last Post: 24th Jun 2007, 19:01
