does anybody know a good mpeg2 (dvd) bitrate calculator? for exemple with VBR, CBR, etc. and audio AC3, DTS, PCM, etc.
thanks for your help.
Results 1 to 13 of 13
I agree, FitCD is an exact and precise bitrate calculator also.Originally Posted by fantomlord
Originally Posted by allenz
Now that's funny!
The link was automatically put into your own post!
"Art is making something out of nothing and selling it." - Frank Zappa -
Wheeeeew !
the things i read here
Now thats too funnyWhats wrong with 352x480? -
If you want to use FitCD for calculating bitrates for DVD-r, which I strongly recommend you do, then you will have to purchase the full version by making a small donation to the author. He will send you Fit2Disk and besides having DVD-r as an output format (I don't believe FitCD has this but I haven't used that version in a while) it comes with some very nice additions.
This program is definitely worth every penny. -
For the bitrate calculation no you don't need avisynth. But if you do use avisynth, Fitcd and Fit2disk have some great features for creating your scripts for you. It will analyze your actual pixel resolution to guarantee correct aspect ratio. This sounds trivial, but alot of commercial DVDs and other productions use generic aspect ratios which can lead to slight aspect ratio errors after resizing.
What is the best Bitrate Calculator ?
By Simmons in forum Video ConversionReplies: 6Last Post: 15th Jan 2011, 09:08 -
bitrate calculator for multiple audio?
By ecc in forum Video ConversionReplies: 4Last Post: 4th Sep 2008, 21:25 -
bitrate calculator
By pcb in forum Newbie / General discussionsReplies: 9Last Post: 1st May 2008, 12:34 -
videohelp bitrate calculator question
By mrgain in forum EditingReplies: 5Last Post: 24th Oct 2007, 16:56 -
Real media Bitrate calculator?
By ViB in forum Newbie / General discussionsReplies: 1Last Post: 1st Jun 2007, 14:34
Thanks all. I'll make a donation and get the calculator
