Is there a way to adjust the final size with DVD2ONE ? I see problems with DVD-RW media towards the end of the disk (last 3 chapters) won't play on standalone player.
I'm thinking of somehow making the movie more compressed so the it's smaller.
Or adding initially filler junk at the end ?
TIA.
try the new program which runs with dvd2one, easy to use.
its called (make it easy)
http://forum.doom9.org/showthread.php?s=&threadid=45104
you will find it there.
thingimijig.
PowerDirector makes final DVD files, size larger than mpg file's size, why?
By Xor2 in forum Authoring (DVD)Replies: 4Last Post: 22nd Dec 2011, 17:29 -
2 pass encoding / Wrong final size
By stanfield in forum Newbie / General discussionsReplies: 26Last Post: 9th Dec 2010, 08:22 -
Adjusting xvid Soft Subs Size for dvd player?
By spiritgumm in forum SubtitleReplies: 7Last Post: 27th Jun 2010, 12:39 -
AutoGK and frame size, adjusting?
By takearushfan in forum DVD RippingReplies: 2Last Post: 19th Jan 2010, 13:54 -
DVD Rip Final Size Differs
By brvignesh in forum DVD RippingReplies: 7Last Post: 10th May 2008, 10:40
