Okay I understand that making a movie file with a higher bite rate (other then that of VCD) will make the vcd considered an XVCD but my question is will the dvd player know this? I would go about this by creating a file with everything else VCD compliant execpt the bite rate then I would burn using Nero and uuncheck the "make VCD compliant" box which would still create the directory structure and still be an mpg 1 but the file would be better quality. My question is would this in fact fool a standalone that is only VCD comliant and not SVCD or XVCD comliant?
And the reason I cannot test this is that my only available DVD player that read VCD's is a half hour drive away so if you guys could help me I'd appreciate it.
I would check here first:https://www.videohelp.com/dvdplayers
In my experience if your DVD player recognizes CD-R/W it will play XVCD but I would not make the bitrate higher than 1500kbps to be safe.
Thinking of selling my sr-w5
By kelvin_paull in forum Capturing and VCRReplies: 1Last Post: 9th May 2011, 13:25 -
I am thinking of buying a new HD camcorder
By Onceler2 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 36Last Post: 2nd Jun 2010, 06:05 -
I'm thinking of going wireless, but want to keep two pc's wired.
By louv68 in forum ComputerReplies: 8Last Post: 24th Jul 2007, 15:17 -
Thinking of switching from XP to Linux...should I?
By videotape74 in forum LinuxReplies: 348Last Post: 28th Jun 2007, 10:28
