I tried to do The Bourne Identity (NTCS progressive film), with force-film unchecked. It seemed to encode o.k.. CCE showed the summary window. I closed that and found a DVD2DVD-r error window underneath. I closed that, and found all the correct files in my folder, so I followed the procedure for IfoEdit. It rebuild the movie. BUT, when I play it on my computer, the audio plays correctly, but the video plays too fast (looks like 2x). What is going on? I have AMD processor and installed the AMD correction for CCE.
Thanks,
Rick
Simple you should not use Ifoedit to author NTSC films. This has been discussed many times before.
Sorry,
I've been out of the loop for a while. What is your favorite authoring software for NTSC (freeware)?
Thanks,
Rick
