I read a post about how I can copy my DVD movie onto a DVD-R disc. It stated that I should use Nero to do this. He stated that I should use the icon "DVD-Rom UDF" and drag the the VIDEO_TS files over to the left side and burn using the DVD-Rom UDF Function at 1.02. My problem is every time I drag these VIDEO_TS files over to the left to burn they are bigger than the 450 MB that Nero will let me burn? How I cut the file size down to 450MB or less so I can burn the files onto a blank DVD-R?
I'm lost on this one
??? First, DVD-Rs hold 4.7GB (or 4.3GB depending on how you look at it) of data. 450MB is smaller than a 74min CDR. It sounds like you want to backup your DVD to DVD-R. Unlike a CD you CAN NOT just drag and drop the files. Take a look at:
https://www.videohelp.com/forum/viewtopic.php?t=109346
There are basically three options:
1) DVD is layer1/single layer/DVD-5. Use DVD Decypter to make a complete back up.
2) DVD is layer2/dual layer/DVD-9. BUT the 'main movie' is less than 4.7GB. Extract main movie and burn to DVDR but lose menus/extras.
3) DVD is layer2/dual laye/DVD-9. And main movie is larger than 4.7GB. Either spilt to 2 DVDRs or re-encode movie at lower bitrate (you can choose to keep or remove the menus/extras). -
get this program.
www.dvd2one.com
It will transcode your dvd rip to 4.36gb so it will fit onto one disc. I would d/l the latest Nero as it supposedly has fixxed DVD compatability. I have not confirmed this yet.
Can you mount an .ISO image to a hard drive , then copy the VIDEO_TS folder
By Bansaw in forum Newbie / General discussionsReplies: 8Last Post: 19th Jul 2011, 18:11 -
Duplicate a DVD....can you simply copy Audio_TS folder and Video_TS folders
By True Colors in forum Authoring (DVD)Replies: 6Last Post: 29th Apr 2010, 14:37 -
ISO file bigger than original video_ts file.
By bbanderic in forum DVD RippingReplies: 8Last Post: 20th Feb 2010, 19:04 -
cannot copy 22.5 Gbyte file with Win XP copy command
By maxtrack in forum Newbie / General discussionsReplies: 7Last Post: 2nd Aug 2007, 14:12 -
Can't Toast VIDEO_TS ( not copy protected)
By rotuts in forum MacReplies: 3Last Post: 21st Jun 2007, 14:28
