Is there a way to get the m2v file from vob file without encoding?? or any format that DVD Maestro can import from a vob without encoding??
You could demultiplex the vob with a program like Tmpeg into it's elementary streams .m2v and ac3. Any authorware should except them.
I would demux with DVD Decypter or smartripper. See the faqs/guides to the left. But here's an outline:
1) Run smartripper
2) Click on 'stream copy'
3) Click to enable stream copy
4) Select the video (and audio/sub) tracks you want to demux. You have to click on each one and choose demux for each stream.
5) Click run
This will rip the standard VTS_XX files and generate an extra/demuxed m2v (and/or ac3 and sub track if you selected them as well).
m2v w/o audio isn't worth much normally so you might want to extract an audio track too. -
http://www.doom9.org/Soft21/Vobtools/Vobedit06.zip
VobEdit 0.6 - VOB editing utility, can split, demux, remux and join VOB files
I like this guy. Easy to use.
I find http://www.doom9.org/Soft21/Subtitles/SubRip_1.15.exe useful for pulling the subtitles for easy import into Maestro.
AVStoDVD crashed on audio encoding.. have m2v video file, but no audio
By arcooke in forum Newbie / General discussionsReplies: 3Last Post: 5th Aug 2010, 14:18 -
Take a .VOB or .M2V file + inverse telecine it so output is .VOB or .M2V?
By DrGori in forum Video ConversionReplies: 20Last Post: 10th Oct 2009, 20:25 -
Encoding WAV and M2V to AVI [high quality]
By duudo in forum Newbie / General discussionsReplies: 2Last Post: 28th Feb 2009, 05:57 -
HELP! Encoding avi to m2v...
By iNDIGOarts in forum ffmpegX general discussionReplies: 2Last Post: 24th Nov 2008, 15:32 -
toast won't do wav, so using mpg file instead of m2v file gets round that?
By jboyd in forum ffmpegX general discussionReplies: 12Last Post: 16th Nov 2007, 14:08
