I have a divx movie (730 mb, 90 minutes) and I would like to convert it to VCD (2x700mb cds). The problem is that when I do the encoding with TMPGEenc the size of the finsihed VCD file is 2.4 gb which is a little too much.
What do I have to if I want to get a 1.4 gb file?
Results 1 to 10 of 10
Which bitrate do you use to encode? Do you use the wizard or a template? If you use the wizard you can use the integrated bitrate calculator to reduce the size of the file. Also: you can lower the audio bitrate in <settings> <audio> to 128 and joint stereo - but honestly, none of that should be necessary for the file you described to make it fit! Some more info on how you encoded it would be helpful.
Joe -
MPEG-1 352x288 23,976fps CBR 1000kbps, Layer-2 44100Hz 128kbps
It says the the projected file size will be 2.4 gb. I don't know what is wrong. -
Which version of TMPGEnc do you use?
Be sure to use the latest TMPGEnc which is v2.510 -
There was some bug in TTMPGEnc 2.59 which made the movies produced by TMGEnc larger that calculated so you better install the newest version 2.510,you can get it grom here:http://www.tmpgenc.net/e_main.htmlOriginally Posted by eiht
thanks...IO'll try with the new version adn I will post the results...thanks again
OK...I made a vmpg/cd that will fit on 2 cds but the problem now is that there is no sound when I play it on my PC even though the information says that there is available audio in the file. What could be the problem now?
I managed to make everything...picture and sound i sok..the only problem is that the picture is not smooth...its a little jerky you know so...what can I do to make it play smoothly?...reduce video bitrate?
thanks -
Reducing bitrate will only make it worse. Try setting 'Motion search precision' in the video tab to high or highest quality, it takes a while but the result will be better.
Converting from RM to AVI problem...
By Citrus in forum Newbie / General discussionsReplies: 3Last Post: 23rd Apr 2008, 17:19 -
Problem converting avi to vcd using CCE
By Hittz in forum Newbie / General discussionsReplies: 4Last Post: 2nd Dec 2007, 20:27 -
Problem converting RM to AVI
By MJS in forum Video ConversionReplies: 9Last Post: 24th Oct 2007, 23:17 -
Converting AVI to xvid AVI - Audio Sync Problem
By foochuck in forum Video ConversionReplies: 3Last Post: 4th Jul 2007, 23:22 -
Problem Converting AVI to xvid AVI (using AutoGK)
By foochuck in forum Newbie / General discussionsReplies: 2Last Post: 3rd Jul 2007, 09:57
