Hey,
I have got a 4cd SVCD of LOTR:FotR (Do not worry, i own it on 2 dvd & extended dvd edition, but wanted to try if its gonna work) and want to put it on a dvd+r with subtitles. I downloaded subtitles for each of the cd, so i guess i must first add subtitles and then convert it into one file. I burned the cd's already so i think i have to extract the mpg's first. My questions are:
- How do i add permanent subtitles using the .srt format?
- How do i join the four cd's?
- Can i burn it on 1 dvd+r, since the movie is around 180 minutes?
- Are there any benefits of putting it on DVD? Are there any noticable differences between Svcd & DVD?
Thnx in advance,
Phoenix4
Use virtualdubmpeg2 to open svcd mpgs and add permanent subtitles and then frameserve to tmpgenc/cce encode. And last author. You dont have to join, you can let the 4 clips play continuesly when you author the dvd.
www.vcdhelp.com/edit#subs
But you will lose quality when you add permanent subtitles because it requires reencoding. -
where can i download virtualdubmpeg2 ?
can i mux m2v and ac3 in virtualdubmpeg2 ? -
Ok, i copy/pasted the AVSEQ01.MPG file to my HD and opened virtualdubmod 1.4.13. But when i try to open the file it gives the following errors:
- Warning: Imcomplete MPEG file detected. Last frame is maybe corrupted
- MPEG Import Filter: MPEG file does not contain video stream
Then i try Virtualdubmpeg2 and it also gives an error:
- MPEG Import Filter: pack synchronization error
What's wrong?
Edit: Few hours later... I tried to convert it first to dvd format with the trial version of Tmpgenc 2.5.10 and then putting subtitles under it, only another problem occurs (sigh...). When i try to add the AVSEQ01.MPG as video file (after first selecting NTSC DVD format with mp2 sound in step 1, to be able to put it on one DVDR) it says that the program can't open it, or that the filetype isn't supported. What the hell am i doing wrong?
I also tried to convert the subtitles from .srt to .sub for me to add them with WinSubMux, but i can't find a converter for it.
PLEEEEZ help me, for i am desperate to getting this thing to work. -
Some guy mailed me with a possible solution and he asked me to postit here. Plz comment the solution or give extra help.
Hi!
I just registered and can not post to the forum.
My solution:
Without subs
1. copy the SVCD dat files to your hard disk (AVSEQ001.DAT, AVSEQ002.dat, etc..)
2. tmpeg: mpeg tools /join (& cut) the 4 (2, 3, ..) dat files to a new mpg file
3. load DVD template and convert (only) the sound to 48 kHz (recommended kbps
224, or whatever you want) (recommended to set external converters: toolame for
wav, ssrc for 44,1 -> 48 kHz)
4. demux the video part of new mpg file with tmpeg /mpeg tools menu to m2v file
5. You have a new audio and video file. Use IFOEDIT, the DVD Author, author new
DVD menu, and add the video and audio files, define the destination directory
then
press OK
HERE YOU CAN ADD SUBTITLES TOO, BUT I DON'T KNOW ANY PROGRAM WHAT
CAN CONVERT FROM TEXT SUBTITLE FILE TO IFOEDIT-LIKE SUP FORMAT.
ANYONE KNOWS THE SOLUTION?
6. You can use ImgTools, or Nero to burn the directory to a DVD. It worked fine
using Imation DVD-RW in Panasonic RA-61 stand alone (my tv is a
Sony 29 inch 100 Hz with DRC)! It was satifying (but a little bit jerky) with
same
media and Sony PS2.
with subs
Same steps form 1-4
5. Use Maestro for authoring and MaestroSBT for converting subs to Maestro
format, then create image and burn with Nero.
(I never tried this way, becouse Maestro was a little bit complicated for me)
Regards!
How to add permanent subtitles with AutoGK and convert to AVI DivX or XviD
By Baldrick in forum SubtitleReplies: 263Last Post: 17th Jun 2018, 15:18 -
How to add Chapters, Subtitles and convert for itunes?
By TC1006 in forum Blu-ray RippingReplies: 1Last Post: 14th Jan 2009, 10:31 -
Add subtitles in HD TS file
By pdurand in forum SubtitleReplies: 3Last Post: 9th Nov 2008, 06:56 -
Trying to Join separate files into 1 file, then add 1 more file and burn
By futureBDburner in forum EditingReplies: 2Last Post: 11th May 2008, 03:50 -
How to add subtitles to an HD .ts file?
By naboth in forum SubtitleReplies: 4Last Post: 22nd Jun 2007, 20:39
