Hi,
I made a SVCD with still images. Almost everything went well, even interactivity with menu, but my DVD player (Pioneer DV-454) reproduces distorted images. A circle becomes an ellipse horizontally stretched, because vertical size is reduced and I have 2 black strips on the upper and on the lower sides of the image.![]()
Changing the DVD player settings is useless.
This happens with each one of the forth resizing methods.
If the svcd is played by a PC player (PowerDVD) the images are right (without any distortion).![]()
Can anyone help me?
Paolo
Are you using v114 or v112? I have similar problem using v114. Try using v112. Try this thread for detail description:
https://www.videohelp.com/forum/viewtopic.php?t=140190
Or use can you TMPGEnc or VirtualDub instead.
Thanks.
I read the thread you suggested me.
I have the same problem with both the vertions (112 and 114).
The only way to have better .mpg imegaes (better, not right!) is to disable the TV aspect ratio correction.
Original images aren't of "recommended size". They are 2048x1536 px.
If I have to resize every image before useing VCDEasy, I prefer to search for an application that doesn't need this (it takes a very long time to do it).
Vegas 8 and still images - always stretched?
By Foxhack in forum EditingReplies: 0Last Post: 13th Sep 2010, 19:11 -
1440x1080 stretched at 1920x1080
By catracho2009 in forum Authoring (Blu-ray)Replies: 21Last Post: 6th Aug 2010, 18:07 -
Final Cut - HD looks stretched
By cupaT in forum MacReplies: 11Last Post: 26th May 2010, 22:16 -
My 4:3 gets stretched like widescreen
By notbillymays in forum Newbie / General discussionsReplies: 6Last Post: 21st Dec 2009, 07:31 -
MKV to m2ts Stretched
By anonymous99 in forum Video ConversionReplies: 14Last Post: 8th Feb 2009, 11:21
