Hi all,
I have a totally persistent Synch problem, I just can't get rid of... The problem only occurs when I encode SVCD - if I encode to VCD everything's alright. The audio gets out of synch gradually as the video plays. Well, here's what I've tried (for weeks now):
1. I check the avi file for bad frames with VDub_mp3 and remove them.
2. I save the audio in a wav file (have tried 44,100 Hz and 48,000) I use no compression.
3. I open TMPGEnc, close the wizard, load the SVCD template (yes, I check the fps in VDUB and select the template accordingly)
4. I load the unlock template and lower the Video bitrate a little bit (1600-2000). I set the motion search precision to high. I choose "full screen - keep aspect ratio"
5. I hit run.
Does anyone have any idea what I'm messing up here?
Thanx, Joe
Does the mpeg2 file play fine on the computer???? Try demuxing your file with bbmpeg then remux it back then burn. bbmpeg can be found in the tools section. Hope this helps.
audio and video not in synch by a second or two problem
By sabathiel in forum Capturing and VCRReplies: 0Last Post: 14th Oct 2011, 21:45 -
Need some help with a synch problem
By kotyczka in forum AudioReplies: 3Last Post: 10th Jul 2011, 07:26 -
Tovid Synch Problem
By Ogilvy in forum LinuxReplies: 4Last Post: 7th May 2010, 14:52 -
Audio Synch problem only after burning?
By MCPorche in forum AudioReplies: 1Last Post: 31st Jan 2008, 19:34 -
Audio At strat in Synch , along of Movie Lost Synch with Video !!!!!
By p_samimi in forum AudioReplies: 9Last Post: 12th Jan 2008, 23:47
