I have thought about DVDr for a while but have been put off because I was told that there is a big problem with compatibility. For instance if I used Philips or Sony tnhe it may not play on certain DVD players even if they were DVD’r compatible.
Q. Is it true that if you use a certain DVD writer it is only compatible with certain DVD players.
Q. Can any writer make a DVD for any DVD compatible player.
Hope this is in the right place
The simple truth is that most modern DVD players will play any type of DVD-R, DVD-RW, DVD+R, DVD+RW.
What may make a difference is the writing filesystem you choose. Use Joliet extensions and you may be in trouble with some players.
According to the manufacturers, DVD+R and DVD+RW are more compatilble with DVD-Video. DVD+RW has the same reflectivity as a dual layer DVD Video.
However, very many people in these forums use DVD-R and DVD-RWs and they don't usually complain about incompatibility of media. However, mind the Nero 5.5.10.0 bugs. This version will just not work (as I found out).
As advise, buy a recorder that can also burn DVD+R. You will find the DVD+RW discs much faster (at X2.4) even compared to X2 discs. I use a couple of DVD+RWs to make backups. 4.5Gb of data in 25 minutes is not bad.The more I learn, the more I come to realize how little it is I know.
Trouble ripping The Ugly Truth with DVD Fab HD Decrypter
By heyjjjaded in forum DVD RippingReplies: 1Last Post: 22nd Dec 2009, 15:29 -
StarGate The Ark of Truth
By stiltman in forum Off topicReplies: 30Last Post: 9th Aug 2008, 17:14 -
Playing VHS on a SVHS Player....The Truth.
By foveauxkid in forum Newbie / General discussionsReplies: 4Last Post: 27th Jan 2008, 22:17 -
At last, *THE* truth! ^_^
By Midzuki in forum Off topicReplies: 2Last Post: 26th Jan 2008, 15:50 -
Which version of Vista do you use? Tell the truth. Don't be embarrassed.
By gll99 in forum ComputerReplies: 146Last Post: 17th Sep 2007, 00:28
