hi
i am trying to put vhs onto comp useing video in tv card and i need to know what format to capture it in ie avi mpeg1 mpeg2 etc and then burn to vcd to get max quality
i have a p4 1.8
thanks in advance
Stool,
have a look at the thread: Making VCD's - Squares and blocks everywhere, from gabestang. I've given him some advice to start.
Perhaps it will work for you too, regards,
Kees Janssen. -
First of all, all you trying, or are you successful at capturing?? Next, capture in .AVI, with Huffy compression, or PicVideo compression. You want more quality?? Skip to SVCD or DVD. It supports the interlace produced from analogue signals that will boost up your quality.
That being said, start reading the How To's on the left starting with Capture, Convert, then Authoring.
Good luck.........
Pansonic super VHS NV FS 88B video recorder
By fourbanks in forum RestorationReplies: 29Last Post: 10th Dec 2011, 14:11 -
Test of SUPER-VHS playback quality for various VCRs
By theaveng in forum RestorationReplies: 5Last Post: 20th Aug 2008, 09:09 -
best way to clean up super 8 footage,thats been transferred to vhs
By BCPOWDER in forum RestorationReplies: 0Last Post: 12th Jan 2008, 11:56 -
super vhs et
By bogb in forum Newbie / General discussionsReplies: 13Last Post: 20th Nov 2007, 22:04 -
I used Super to convert AVI to mpg VCD...........................
By videonewbie69 in forum Video ConversionReplies: 2Last Post: 23rd Jul 2007, 12:34
