I have tried this, but to no avail. I have a four disk svcd, which when converted will not fit onto a single dvd (7.5gb). The SVCD quality is perfect and I don't mind having the same quality, but with no disk swaps!
Is there a way I can do this, as most burning programs I have used tell me that I cannot burn an svcd to DVD, only to CD-R/RW.
Ay help on this would be much appreciated.
(It is driving me a bit crazy!)
I am not sure if I understand correctly what you are trying to do but first of all: svcd is not compatible with dvd.
The least thing you should do is convert the audio to 48khz but even then the resolution should be a problem. Try converting it to a CVD compatible resolution which is 352x576 or 352x480 then you can put the movie onto a dvd. -
h@tcher wrote.....
Have you tried this guide ? .......
https://www.videohelp.com/svcddvdr.htm
All i suggest is that you join the SVCD's together with Tmpegnc and then follow the guide. -
Thanks for all your help guys. This has really helped. It s good to know that a newbie like me can get some help!
Once again, thanks.
H@tcher
a disk error occurred during a write operation
By SE14man in forum ComputerReplies: 8Last Post: 8th Nov 2011, 02:16 -
Backing up DVD/Blu-ray to disk, watching movies directly from disk to TV.
By mb312 in forum Newbie / General discussionsReplies: 0Last Post: 11th Feb 2010, 16:35 -
Write DVD to Disk
By Leo48 in forum Newbie / General discussionsReplies: 5Last Post: 7th Dec 2009, 19:07 -
how can I write to a DVD+R DL
By agent222 in forum Authoring (DVD)Replies: 12Last Post: 12th Apr 2009, 15:08 -
DVD has no Subtitles. How do I write my own?
By TRUSTpunk in forum SubtitleReplies: 10Last Post: 20th Jul 2007, 00:10
