newbie here guys, thanks for taking time here, I really need help with my capturing from winFAST PVR, the quality is good and sound is good when playing from my media player, but then, after i transfer it to VCD and play it to my VCD player, the audio is cutting...
My stat: P41.5Ghz,Geforce264mb,128mbddr,40GB7200seagate,lea dtek tv2000xpdeluxe, VIBRA 128 creative.
i use Winfast PVR for capturing and in MPEG format (for VCD - NTSC)
352x240,29.97fps
i use Nero Burning ROM for burning CDs
Audio is pausing, cutting, you can't hear a good music. just like when playing your damaged audio cd
pls. i need help!
What do you mean by 'cutting' ?
What format do you capture in ?
What do you use to encode ?
What do you use to author and burn ? -
Ive had the same capture/tuner card for a couple of weeks and am yet to get the best out of it. I was also using a Vibra sound card & found the sound distorted at all recording levels, by luck a friend had a spare SB Live sound card which solved the distortion problem.....not sure if this will help with your woes.
Ive also captured a few vcd mpegs (pal) on the fly with this card, the output was reasonable, but will try capturing to avi 1st. I'm presently using the Winfast PVR to capture to 720 x 576 avi using Huffuv codec, then tmpgenc to mpeg2. So far so good, changing the master stream from audio (back) to video solved any sync probs.Movie only DVD9 to DVDR guide.
http://www.angelfire.com/droid/dvdr/guide.htm
avidemux for capture cutting and cleanup..
By cowmix in forum Capturing and VCRReplies: 4Last Post: 3rd Sep 2009, 23:00 -
Trying to use VirtualVcr with Leadtek Tv2000 expert.
By GLE3 in forum Capturing and VCRReplies: 0Last Post: 20th May 2009, 09:46 -
Problem with WINFAST TV2000 XP Expert tv capture card.
By trueman in forum Capturing and VCRReplies: 1Last Post: 5th Aug 2007, 11:00 -
leadtek dtv1000t digital tv tuner card capture resolution.
By g12345567 in forum DVB / IPTVReplies: 4Last Post: 22nd Jul 2007, 11:56 -
Leadtek Winfast TV2000 xp deluxe help
By Nuwanda in forum Capturing and VCRReplies: 0Last Post: 6th Jun 2007, 13:22
