  1. I have hundreds of pictures of frogs downloaded on my computer and I
    would like to know if it is possible to burn them onto Cds so I can clear them out of my computer. Can this be done? If so, how ?
    Thanks, Petr.
    Mar 2001
    Antwerp - Belgium (Europe
    Yes, but what do you want to create?
    A plain DataCDR, with those pictures in a directory as pure pc-files or a PhotoCD (which then can be threated as a VCD).
    For the first, use Nero or WinOnCD or whatever burner.
    For the other, search this site for how to create a PhotoCD.
    Regards,
  3. Betamax is right, there are enough options available now that it is difficult to discuss them all. Spend some time (a lot of time) investigating this site and you'll likely find exactly what you want. After trying a lot of different things I finally settled on Ulead's DVD Pictureshow. Some people have had problems with this software, but for me it addressed my needs (hundreds of pictures divided into several catagories with maximum possible image quality).
    Someone is bound to have a different opinion, so bring it on!
