    Jan 2003
    N. America
    When I view my xvid in WMP it appears as it should being a 16:9 aspect. Black bars on the top and bottom, with picture to the edges. However, after following the guides on the site, and trying to convert to SVCD for burning with nero, when I preview the finished product in WMP it has the 2 black bars, but the video does not go to the edges of the screen anymore. Any suggestion? Thanx.
  2. Member Conquest10's Avatar
    Chicago, IL
    gonna need a little more. what edges does the video not go up to that it has to?
    Jan 2003
    N. America
    The left and right sides of the sreen border. There is a black gap there, and in the original xvid there are none.
  4. Member Conquest10's Avatar
    Chicago, IL
    in the advanced tab, did you use full screen (keep aspect ratio)?
    Manchester, England.
    Burn it and play it on your standalone, I reckon it will be OK. I just encoded a film last night, I've just checked it and if I preview it in WMP I get the same thing. It plays correctly on my standalone though.
  6. My experience is just like ARAB's - you'll be alright!
    Jan 2003
    N. America
    Thanx Guys, I'll try it tonight. Hopefully all goes well.
    Aug 2002
    If you play your files in DVD software such as Power or WINDVD it should play ok.
