Hey,
When I split a DVD to 2 DVD-Rs using IFo Edit, the first disc works fine but the second disc's time search doesnt work. Like in PowerDVD, u try to move the time but it randomly picks a place to start the video but the time is wrong. Like I will start it at the beggining anf move the time and when i let go the time markers stays and contines but the video is from the beggining. Same thing all over the disc. Seems to jump to chapters. Any suggestions?
I'm not sure exactly what method you are using but I too had this problem until I did the spilt mannually. I ripped half of the movie to the first folder with Smartripper (VOBS only) then the other half to the 2nd folder. I then renamed the files in the second folder to make sure that they are in sequence, such as VTS_1_1, VTS_1_2, VTS_1_3. Then, in both folders I created new ifo's with ifo edit, and also in both folders I corrected the VOB pointers and selected "Get VTS" sectors all with IFOedit and then burned the VIDEO_TS folders with RecornNowMax and both discs worked fine. There are subtitle issues with this process but I don't care for subtitles so it dosent't matter to me. Let me kow if you need more detailed help. Good luck.
Live Long, Play Hard, Think BIG! -
Ya, i need subs because I usuallly rip anime. Does anybody have anyother method to do this other then ifoedit then?
How old is the oldest working burnt disc that you have made?
By yoda313 in forum Newbie / General discussionsReplies: 32Last Post: 14th May 2010, 06:10 -
Working the search enginges for rankings
By videobread in forum ComputerReplies: 3Last Post: 6th Dec 2007, 12:53 -
Philips DVP 5982 Time Search Question
By TufrThanu in forum DVD & Blu-ray PlayersReplies: 5Last Post: 18th Oct 2007, 15:05 -
Is it possible to 'Time search' through Divx files on Philips 5960?
By Kibz25 in forum DVD & Blu-ray PlayersReplies: 3Last Post: 3rd Aug 2007, 10:15 -
Corrupted DVD-RW VR disc that has working video
By Mark001 in forum DVD RippingReplies: 2Last Post: 9th Jun 2007, 18:17
