ok, i'm tired of having problems watching videos, so i will finally install nimo pack on my computer as i read that thereis all codecs in there. my question is: do i have to unistall the codecs that i have now in my computer before i intall nimo, or it is ok to install nimo without uninstalling others? i'm asking that because i read somewhere that you can have problems if you don't unistall the current files first.
thanks a lot.
take care.
you should be fine... an overwrite prompt will come up and you can either overwrite them all or none it really doesn't matter at least it didn't for me..
You win some, and you lose some, and some get rained out...
What is the best Codec Pack?
By cim in forum Software PlayingReplies: 84Last Post: 8th Jul 2012, 12:45 -
Klite Codec Pack
By pepegot1 in forum EditingReplies: 6Last Post: 2nd Feb 2012, 22:39 -
Klite Codec Pack
By pepegot1 in forum EditingReplies: 1Last Post: 27th Jan 2012, 14:44 -
K lite codec pack
By Pumkinhead in forum Newbie / General discussionsReplies: 14Last Post: 26th Oct 2010, 14:12 -
Codec Pack selection?
By therock003 in forum Newbie / General discussionsReplies: 4Last Post: 21st Oct 2007, 11:50
