Hello,
I just upgraded to the latest version of TMPGEnc Plus and when I go to save my file (CBR or VBR) it wants to save it as a m2v & wav file. There is a box to uncheck saving as independent streams, but it is grayed out so I cannot uncheck it. What setting is causing this box to lock? What can I do to save it as 1 mpeg file as it did with prior versions?
Thanks,
-nick
Use the 'Load' button. From the Extra folder, select 'Unlock'. I don't know what you mean by 'save' though. The 'Video Source', and 'Audio Source' that you see displayed are your input, not your output. The Output filename should be MPEG, assuming you have both audio, and video inputs.
Using the Unlock template should at least make all of your Stream Type settings selectable though.Impossible to see the future is. The Dark Side clouds everything...
No audio when saving .MPEG file from VOB stream using MPEG Streamclip?
By Bix in forum MacReplies: 3Last Post: 25th Jul 2010, 17:12 -
Not Saving the File anywhere
By MrBoiler in forum ffmpegX general discussionReplies: 8Last Post: 31st Jan 2010, 07:17 -
Adding a text logo to a video file without re-saving it to another file?
By coxanhvn in forum EditingReplies: 4Last Post: 19th Dec 2008, 15:03 -
File Size Limit With TMPGEnc Plus 2.5 or MPEG-2?
By RABinMS in forum Video ConversionReplies: 5Last Post: 10th Feb 2008, 14:30 -
TMPGEnc DVD Author file size too big issue
By silverwolf0 in forum Newbie / General discussionsReplies: 7Last Post: 25th Dec 2007, 17:53
