Hi there...
I have a movie encoded in the XVCD format. It is all one file and too long to fit on one CD-R. So, I used TMPGEnc to cut it into two. I was careful in letting TMPGEnc know that it was non-standard VCD. I can play the cut up file fine on my computer using RealOne player.
I then burnt the cut-up file on to a CD-R using Nero. I have Apex AD-1500. When I play the CD-R on the Apex player the picture and sound play do not play smoothly. Any help will be appreciated.
Twindad![]()
Every thing is there just do like me read read and read the guide and donwload all the program you need. Here is the guide you need it's here under dvdrip. The Original Official Guide by Sefy Levy
Bye the way if you just want to play it on your computer dont botter with the guide just do it in SVCD.
K-Lite Codec Pack messing up burning IMG audio cd burning
By Blå_Mocka in forum AudioReplies: 24Last Post: 26th Aug 2010, 06:27 -
Iso burning faile, folder burning succeed
By cd090580 in forum DVD & Blu-ray WritersReplies: 5Last Post: 3rd Dec 2009, 15:46 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 14:14 -
Advantages - disadvantages to burning video folders or burning an ISO img
By theewizard in forum Authoring (DVD)Replies: 14Last Post: 26th Jun 2007, 16:19
