I think my computer hardware is not the problem. Pentium 4 w/ 2 GHz and 256 M RAM. 25 GB left on drive. I use Win TV. I capture from my VCR using virtual dub (which helped compared to Hauppauge software). I have used the virtual dub temporal smoothing filter and sharpen in combinations. These helped alot.
The only thing I can think of which causes my final product to be so "blotchy" compared to the original VCR source is my use of Nero burning software. It uses ARTEC -WRR 4848 to burn my VCDs. I also use JHepple for AVI to MPEG conversion. I have bought upgrades to both to do MPEG2.
I have a 60" projection TV, but that shouldn't matter since my metric is to get back to the VCR quality that it came from.
that blotchiness is compression, try capptrring straight to mpeg and change the vd rate to min 1,500
Blackmagic Intensity Pro: Can't capture from any VCR source
By mvrx in forum Capturing and VCRReplies: 22Last Post: 31st Dec 2012, 14:42 -
PS3 VCR Quality
By s3r19lk1ll3r in forum Newbie / General discussionsReplies: 13Last Post: 11th Oct 2010, 22:10 -
Help with keeping quality for archiving my video files. Interlace source
By drewzor in forum Video ConversionReplies: 11Last Post: 8th Mar 2010, 19:32 -
VCR quality help
By Ealdric-1379 in forum Newbie / General discussionsReplies: 1Last Post: 15th Oct 2008, 14:28 -
exporting .m2v source files out of fcp without quality loss
By MacNiles in forum MacReplies: 9Last Post: 17th Aug 2007, 09:39
