I have seen these letters quite a few times, and I just can't quite come up with what it actually means. I have seen it attached to numerous software packages (ie. vcd image AND BeSweet)
Just to add to HEX's message. VCDImager, CDRDAO, BeSweet and several other programs are comman line based (ie. dos prompt). Since many people hate having to type in command lines, it's easier for them to use a GUI.
For example, VCDImager's XML files can be very complicated, but a GUI like VCD Easy or TSCV does 'most of the work for you.' -
Thanks for the quick replies. I have seen this acrynom for quite some time and never could figure it out. Then, immediately after I installed BeSweet (without GUI) it gave a message that I could install the GUI version because some users like it better. That's when it clicked, in my mind; "Graphic User Interface".
Thanks for confirming my hypothesis
Help adding audio to "DVD slideshow GUI"
By Kiwi999 in forum Newbie / General discussionsReplies: 7Last Post: 22nd Mar 2012, 01:34 -
ffmpeg GUI that can "copy" into a different container?
By AlanHK in forum Video ConversionReplies: 4Last Post: 22nd Jul 2010, 02:37 -
how to fix "WARN: unknown mpeg2 aspect ratio 1" in DVD Author GUI
By extent in forum Authoring (DVD)Replies: 10Last Post: 23rd Nov 2009, 07:57 -
Question about secret hidden "Back" button in Gui For DVD Author
By jimdagys in forum Authoring (DVD)Replies: 2Last Post: 15th Dec 2008, 03:17 -
"Non valid Key" in GUI for DVD Author
By Harry Cover in forum Authoring (DVD)Replies: 1Last Post: 11th Nov 2007, 14:35
