I have a few videotapes with less than ideal quality that I need to capture for burning onto DVDs. The big problem is that the scene as a whole occasionally jumps a bit for what looks like 1 (maybe 2 or 3) fields before returning to normal, and occasionally an entire field will be corrupted beyond repair.
A few months ago, I went through one such capture and edited out the irreparable fields using Ulead Video Painter to replace the bad field with the last good field, but it took forever just to fix 15 minutes worth of video.
Are there any utilities (preferably free) that, given a source file in some supported format (avi, mpeg, mjpeg, etc), can automatically recognize corrupted frames and replace them with the previous or following good frame? Or recognize jittery video and automatically fix it?
did you try Virtualdub ?
Video > Scan for bad frames
then save avi
what format are you capturing to ? -
I can capture to just about anything... probably HuffyUV or Morgan MJPEG. Normally I capture using ATI MMC since it can do halfway decent realtime MPEG-2, but obviously something like this is going to take a little more offline work and isn't a realistic candidate for realtime MPEG-2 capture.
I didn't know about VirtualDub's "Scan for New Frames"... that's exactly the kind of tip I was hoping for
Ultimately, I'm making a 1/2 DV-1 (352 x 480) MPEG-2 file suitable for burning to DVD.
problem on captured VHS frames
By stefangs in forum Capturing and VCRReplies: 13Last Post: 5th Mar 2012, 02:38 -
ADS Pyro A/V Link - Firmware u/g to fix VHS dropped frames
By pbanders in forum Capturing and VCRReplies: 16Last Post: 24th Mar 2011, 23:40 -
Captured VHS movie and .srt subtitle not sync'd. Any way to fix?
By snafubaby in forum SubtitleReplies: 2Last Post: 17th Aug 2009, 02:52 -
captured video vertically squeezed, fix during conversion?
By krcoggins in forum Video ConversionReplies: 2Last Post: 16th Feb 2009, 16:32 -
I need your guys help, repair/fix corrupt video
By jace89 in forum Newbie / General discussionsReplies: 2Last Post: 14th Aug 2008, 19:52
