Well, I'm managing to work through some of my earlier problems, experiencing some really weird ones now though :> I've encoded an MPG from a DivX running at 24FPS, I corrected the framerate in TMPGEnc before creating the MPG of it..when I played back the MPG in Media Player everything was just fine. However, when I tried burning it to a CD and playing back in the DVD player, the audio is about half a second ahead of the video..great :> I'm not sure at all how I'd go about fixing this, has anyone experienced similar problems?
you and about 90%(I took a precise scientific survey) of everyone else
Their are guides on this site that deal with correcting this....from demuxing the audio and expanding/comprssing it, to resampling the frequency.
https://www.videohelp.com/edit
scroll down till you see the fixing audio synch part -
Hmm..I'll have to give those a read over again :> Is it unusual for the audio to be out of sync on the player only, though? When I take the same VCD and play it in WinDVD the audio's fine. Unusually enough this also only occurs with two or three VCD's I've got, the other ones seem to play fine.
Audio has problems in Windows Media Player but not in other audio apps
By brassplyer in forum Software PlayingReplies: 7Last Post: 23rd Sep 2011, 17:12 -
Problems with Audio
By fi3ryfalc0nZ in forum Software PlayingReplies: 3Last Post: 7th Dec 2009, 19:23 -
audio problems
By minigamer in forum Newbie / General discussionsReplies: 1Last Post: 21st Dec 2008, 12:03 -
Audio Problems
By macuser1960 in forum ffmpegX general discussionReplies: 9Last Post: 26th Feb 2008, 15:46 -
Problems w/Audio
By itsmevic in forum AudioReplies: 1Last Post: 9th May 2007, 01:53
