  1. Hi,
    I have a problem playing my DVD "creations" in any DVD player, even my PC one. The movie will play great if I "manualy" start the DVD playing application, but not with just inserting the DVD disk to the drive, like any other "Original" DVD.
    I have used different DVD2DVD backup programs (DvdXcopy, DVD2One, etc...) and also DVD authoring programs for my Digital Cam (like Ulead workshop, movie factory etc..), and all will have the same result (plays only when launching (manualy) the DVD playing application - PCDVD, WinDVD etc.
    I'm using "Memorex" DVD-RW and Nero 5.5.10. I have also used the build-in burning section in DVDXCopy 1.4 and same result.
    I couldn't find anyone in the forum having a similar problem and everyone is successful, so I assume that I missing something here...
    Help....
    Shah.
  2. Hmm? Are you saying that your DVDR discs do not autoplay. Or are you saying that they do autoplay but that the quaility is worst/off compared to playing them manually?
    If the first, you need to set the 'play first' in your DVD authoring program. I normally use Maestro so I only know that program. Look through the helpfiles for whatever you use.
    If the second, I have no idea
  3. Thanks for the reply,
    Its the "autoplay" only. The quality is fine (1:1), its just not playing automaticaly when you just insert the DVD disk to the drive.
    I have noticed the "play first" option, but with no luck there.
    Thanks again...
    Shah.
