This is driving me crazy. I get perfect working copies in my stand alone player using DVD-Video. BUT, many here say that it is better to use UDF (I think that's it, I can't check now because I'm copying a DVD on my good computer as I type here). Anyway, I've tried - physical partition, 1.02, etc, force video compatibility mode on and off, and not a single disk works in my player. I make an AUDIO_TS folder (stays empty) and a VIDEO_TS folder into which I drag all the video files like I do when I use DVD-Video..., and I get disk error in my player. What are you guys doing differently? This is eatting me up....![]()
Thanks,
Rick
If DVD-Video works for why are you trying to break it ?
Pinnacle Studio 8 and DV home video editing (ver.9 already home) -
It works in my current player, but I've heard that DVD-Video setting is not as compatible with all players as using the UDF setting. Plus, it is just eatting at me that everyone else uses it and I can't get it to work.... With UDF do you make a disk image first?
Thanks,
Rick -
The problem was that previous versions of Nero (before 5.5.10.7) had a bad DVD-Video template, so it was better to use UDF or ISO/UDF. While most older players work fine with UDF, some newer players need ISO/UDF (the format that ALL commercial DVDs use).
Best thing is to use latest Nero, with DVD-Video - this seems to work in all players (inc. Xbox). Not sure what it does, but check 'DVD-ROM booktype' when burning, especially for +R discs, for maximum compatibility.
Hope this helps,
Mark. -
I used DVD-Video in 5.5.9.17.0 and it worked on 3 different DVD players. There was problem with 5.5.10.0 version. I am not sure how is current 5.5.10.7b. Maybe you can try your disks in some store around you and see if it will play. Just be aware that not all players play all formats.
Noobish Nero DVD Burning problem (no space available for recording process)
By windowlicker in forum Authoring (DVD)Replies: 7Last Post: 22nd Dec 2014, 11:24 -
Svcd Burning Problem with Nero 7
By Soixante in forum Authoring (VCD/SVCD)Replies: 4Last Post: 3rd Nov 2010, 11:59 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 13:14 -
Sound Problem Burning DVD with Nero 7 and TMPGEnc
By brandonc in forum Authoring (DVD)Replies: 4Last Post: 28th Nov 2007, 19:40 -
nero burning problem
By peterjitonks in forum Authoring (DVD)Replies: 2Last Post: 26th Aug 2007, 13:40
