Im burning DVD in SVCD or XVCD and i want to know if its possible to burn it with the french version. Here is how i procede.
Copying - Smart Ripper
FrameServing - DVD2AVI
Encoding - TMPGEnc or TMPGEnc Plus
Chapters - Chapter-X-Tractor
Authoring - VCDEasy
Burning- Nero burning rom
What is the step for the french record if it's possible.
The french version is on the original DVD in the menu section.
In the DVD2AVI you need to select the corresponding audio track that is the french one. track 1 is usually english so try the others. select the proper audio track that you want and then save project.
No, french is not possible on a DVD
Panasonic DMR-ES45VS, keep those discs a burnin'
Convert DVD with choice of audio language and burned-in subtitle language
By theproof in forum DVD RippingReplies: 2Last Post: 24th Jun 2010, 17:34 -
VHS to DVD software, French VCR different?
By Baya87 in forum Capturing and VCRReplies: 3Last Post: 11th Jan 2010, 00:48 -
DVD Fab shows Eng and French subpicture for a Swedish original
By loninappleton in forum SubtitleReplies: 2Last Post: 17th Dec 2009, 15:37 -
Guide Needed for Authoring Multi Language DVD with multi language menus
By kemimich in forum Authoring (DVD)Replies: 2Last Post: 24th Dec 2008, 16:46 -
Authoring Multiple Language DVD with multiple language menu options
By kemimich in forum Authoring (DVD)Replies: 7Last Post: 8th Sep 2008, 16:29
